Browse Forums Outdoor Living 1 Jan 17, 2021 9:30 am Hi all, I bought a used VICTA straight shaft TTS2226AB trimmer. Works fine but the carby could do with a service. It is getting harder to start and motor to remain running while using. I just changed a new spark plug hoping this will fix it but no. I could either send it for professional servicing for $55/hour plus parts or buy the service kit and do it myself or replace it with a new carby. So on ebay an after-market carby for this model is about $30 delivered. I thought that is really cheap but not sure if an after-market replacement can last me say one year. Has anyone replaced their carby with an after-market one and what is your experience? Thanks. thank you! do we need to get this or our builder before we commence new build on the block? 2 10404 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9948 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6138 |
