Browse Forums Outdoor Living 1 Oct 07, 2008 12:37 pm What would be the average price difference per square metre between a composite decking (such as modwood) in comparison to natural decking (such as merbau)? Or is that a piece of string question?
Thanks! Re: Composite vs Natural Decking 2Oct 07, 2008 6:48 pm To compare them fairly you need to include the cost of coating the timber deck as well as the timber itself - that is the variable.
90mmx19mm merbau is around $43 / sq. metre 88mmx23mm Modwood is around $85 / sq. metre If you use a decent decking finish like Sikkens which is about $140 for 5Lt for a hardwood finish such as Cetol HLS then add the time etc. and regular recoating if its not covered ( eg. around a pool) - after a few years the difference is gone. Over a longer period the Modwood can even work out cheaper. Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10973 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6710 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15798 |
