Building 8 x 6 meters deck
I would like to build 8m x 6m free standing deck. What would be the best size timber to use? Is 140 x 45 bearers and joist are suitable?
Thank you
It's dependent on the bearer and joists spans?
but I would double up the bearers
Projects to do after handover
Chris
Chris
Hi Chris
Thanks for your reply.
I will have 3 rows of 5 posts along our 8 meters deck. I would like to use 140x 45 timber for the bearers and joists.
I will double up the bearers as you suggested.
The bearers span would be 1.6m and the joists span will be 2.5m approx.
Let me know if that makes sense.
I would like for the deck to be quite solid, no bounce. So if I have to have 6 post instead of 5 I will.
What do you think? I'm open for any suggestions.
Thanks
joists at 450->600 mm this will depend on your decking choice
Cheers
Yep, keep the bearer spans to around 1.5m->1.6m
Cheers
Cheers
Hi Chris
Thank you for that information.
I will use 90 x 90 posts set 500mm below ground level. I was thinking to use 65 x 90 m10 pryda stirrups screwed on to the concrete and 90 x 90 post on top of this and then the bearers. What's better and up to code?
Are the stirrups strong enough to hold the deck?
Thank you
I am building in claymore NSW and this is shown in the building envelope plan. …
6/09/2023
I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be…
28/12/2023
2
Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which…
