Browse Forums Outdoor Living Re: Can u deck over existing concrete slab? 41Feb 12, 2019 12:11 pm You can also check out WPC decking. A decent alternative to wooden deck at only a fraction of the cost (only few bucks per sq m for the material). Can be laid in DYI mode. Doesn't require waterproofing, etc. Re: Can u deck over existing concrete slab? 42Mar 28, 2019 12:31 am I have some photos, but will have to dig for them and post them a bit later. Basically, I made stringers from pressure treated wood, then screwed those to the sides of the concrete steps. The treads fasten to the stringers and also rest on the concrete steps. Mine overhang by only about 10" on one side, so I didn't have to do anything else to add structure, just another stringer. Re: Can u deck over existing concrete slab? 43Jun 10, 2019 9:42 pm This is a great topic. I had a similar idea but didn't know if it was possible. I want to get rid of the shed and lay decking over the concrete slab. The shed and the concrete slab was a DIY project untaken by the previous owners and it doesn't look the best. Hopefully in the next few years. Re: Can u deck over existing concrete slab? 44Dec 05, 2021 8:30 am wouldn't suggest laying the timber straight down on the concrete eventually the rain will rot the timber, but even worse the water will cause the timber to swell and move the decking boards and they will warp... Water makes timber swell and expand even treated timber Simple google search Before installation of your treated pine decking at home, it is crucial that your sub frame is correctly designed and installed to accommodate your deck. ... Treated pine decking will take up or lose moisture depending on dryness or moisture from the environment, causing the timber to expand or contract Can assure I've seen this expansion crack bricks and concrete over the years.. The more you expose to a full surface like using the full run of the concrete the more chances it has to swell and expand .. Solution stumps, deck feet or shims... Good luck One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 1236 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6476 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5953 |
