Thats a very inhospitable attitude...
What happened to the caring sharing Mish..
Browse Forums Outdoor Living Re: Decking and Weep Holes 21Feb 11, 2008 1:31 pm Michelle just we don’t need to make it easy for them. Thats a very inhospitable attitude... What happened to the caring sharing Mish.. Re: Decking and Weep Holes 22Feb 11, 2008 1:44 pm I got bloody white ants!!!!!!!!!!
Scared the hell out of me! And no….their not welcome! But you are….any time you like…………….. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Decking and Weep Holes 24Feb 11, 2008 2:47 pm If the termite barrier is around the perim of the deck then it's ok.
If the barrier is at the house then there has to be 25mm clear gap to any timbers. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Decking and Weep Holes 25Feb 11, 2008 3:23 pm I think the crown will be better…..shucks!!!!!
I’ll start looking onto it soon!!!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11966 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7591 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6184 |
