Browse Forums Outdoor Living Re: Vanderlay's holiday project!! (so far).... 21Jan 03, 2008 8:14 pm I can certainly tell you the best way to do it and give you a better price for materials than a builder would
As for doing it, I'm struggling finishing my own at the moment Re: Vanderlay's holiday project!! (so far).... 22Jan 03, 2008 8:17 pm Dukekamaya I can certainly tell you the best way to do it and give you a better price for materials than a builder would As for doing it, I'm struggling finishing my own at the moment YES... It’s hard, no spare time! But you’re doing good work! Must come in and meet you one day! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vanderlay's holiday project!! (so far).... 23Jan 04, 2008 8:11 am Dukekamaya From memory 90x90 F7 just spans 1800mm as a bearer so its used fairly regulary when there isn't space for a traditional size bearer. Ours are about 1400 apart. So nice and solid Built Porter Davis "Dromana" 2007. Re: Vanderlay's holiday project!! (so far).... 24Jan 04, 2008 8:12 am Michelle By the way V……it’s about time you got internet at home isn’t it???? SLACKER! I know...but at the moment we only have telstra internet available.....and we dont like them!! and how else would I spend my time at work!! Built Porter Davis "Dromana" 2007. Re: Vanderlay's holiday project!! (so far).... 25Jan 04, 2008 8:17 am Get Internode….. their good! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Vanderlay's holiday project!! (so far).... 26Jan 04, 2008 8:19 am vanderlay and how else would I spend my time at work!! Ummmmmmm working ( & productively) - i would say !!!!!!!!!!!!!!!!!! Re: Vanderlay's holiday project!! (so far).... 27Jan 04, 2008 8:19 am Michelle Get Internode….. their good! would love too....but no-one wants to help us in the "country" We couldnt even get optus phone connected, let alone internet!! Built Porter Davis "Dromana" 2007. Re: Vanderlay's holiday project!! (so far).... 28Jan 04, 2008 8:21 am **Phoenix** Ummmmmmm working ( & productively) - i would say !!!!!!!!!!!!!!!!!! Never!!!! Its much more entertaining on here..... Built Porter Davis "Dromana" 2007. Re: Vanderlay's holiday project!! (so far).... 29Jan 04, 2008 8:24 am vanderlay **Phoenix** Ummmmmmm working ( & productively) - i would say !!!!!!!!!!!!!!!!!! Never!!!! Its much more entertaining on here..... Tooo True!!!!!!!!!!!!!! Re: Vanderlay's holiday project!! (so far).... 30Jan 05, 2008 5:48 pm Nice deck V.
Look forard to celebration pics and the dripping BBQ fat and sauce on it as it's christening. Good to see your Avatar is reflective of yur work too Steve Re: Vanderlay's holiday project!! (so far).... 31Jan 05, 2008 11:31 pm Hi Vanderlay
Excellent work with the deck. Just a question regarding the construction as i'm planning my own deck shortly. Did you use a wall ledger to support the joists near the sliding door?? If not what was the distance from the house wall to the first bearer?? Thanks Anthony Re: Vanderlay's holiday project!! (so far).... 32Jan 06, 2008 12:41 pm wanted If not what was the distance from the house wall to the first bearer?? Thanks Anthony Depends on the joist you use - a 90 x 45 F7 has a maximum continuous span of about 1600mm. If you want it further you need to go to a 120 or 140 x 45mm Re: Vanderlay's holiday project!! (so far).... 33Jan 06, 2008 1:48 pm Duke while your into bearers and joist sizing mode.
What size would I require to span 5400mm and only support it at each end. The pool is 4100mm wide if that makes a large difference in size and cost of the bearers, then I could support it at this distance as there are existing posts beside the pool that I can re-use. Either way, one end would be attached to a brick wall and supported at the other end by a post. Also what size posts will I require? I want build a deck over the top of my swimming pool that is now turned into a water tank - hence the large span. Steve Re: Vanderlay's holiday project!! (so far).... 35Jan 06, 2008 5:39 pm What is the whole size of the deck? A bearer's size is dependant on the 'floor load width' and whether single/continuous span etc.
A quick check says 2/290x45 F27 Hardwood or a 390x80 GL8 T/pine beam for a 5.4m span with a load width of 1200mm i.e. 2400mm across to next bearer (joist span) or You could use 2/290x45 F7 treated pine if its only 4.2m - much cheaper. F27 290x45 is about $50/metre and you would need 10.8m Re: Vanderlay's holiday project!! (so far).... 36Jan 07, 2008 9:13 am wanted Hi Vanderlay Excellent work with the deck. Just a question regarding the construction as i'm planning my own deck shortly. Did you use a wall ledger to support the joists near the sliding door?? If not what was the distance from the house wall to the first bearer?? Thanks Anthony The first bearer was about 300mm away from the doors. Cheers. Built Porter Davis "Dromana" 2007. Re: Vanderlay's holiday project!! (so far).... 37Jan 07, 2008 9:17 am Ok...after working from 9am till about 8pm yesterday we have all the decking on!!! Just got to tidy the edges up and stain it
Hey Luke....we ended up getting the sikkens cetol.....the sample bits we have stained look great!! Thanks for the tip!! Built Porter Davis "Dromana" 2007. The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us. 12 6015 Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4825 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 28039 |
