Browse Forums Outdoor Living 1 Mar 02, 2022 2:05 pm Hi All We have built a KDRB in one of Melbourne's inner north suburbs of Melbourne. We are about 2 weeks away from handover and just wanted to query what the acceptable condition of the backyard is when they hand the house over? Ours isn't horrible, seems to be a lot of clay and a little rubble. But the height of the backyard is definitely not the natural ground level when the property was handed over to the builder. Its probably 100-200mm higher, which you can see from the heights of the soil against the plinth of the fencing. I believe they have spread the spoil over the rear to try level it out... We had a landscaper over to have a look and they have advised the level is quite high and would cost quite a bit for us to remove due to the time it will take because of smaller access. What are the requirements in the HIA contract? I cant seem to find anything about it being left in the same condition? It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9664 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25568 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 14951 |
