Browse Forums Kitchen Corner Re: HELP! Kitchen benchtop slab gap line's edge has crack un 5Jul 30, 2020 9:27 am The stone isn't cracked, the supporting structure has moved. Nothing to serious, scrape it out and clean with thinners, run some new sealant into it, spray with soapy water and remove excess with a flat scraper (kitchen guys used a scrap of laminate) You state an older house, you have to expect movement, not an installation defect Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12929 I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 7489 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2268 |
