Browse Forums Kitchen Corner Re: Island bench size 3May 25, 2020 8:03 am We have 3m x 1.1m and we are loving it! Upto 3m easily achievable without joint as most of the slabs comes at that length, Quantum Quartz has XL range has 3210mm for length for a single slab. Width wise anything beyond 1200mm will look squarish than a nice long rectangle IMO. Also, the gap between island and stove-benchtop is 1300mm, imho, it could be a tad too far for an efficient kitchen working triangle (https://www.sketchplanations.com/image/174951459161) . We have 1100mm gap and works beautifully. Re: Island bench size 5Jun 26, 2020 2:16 am Yours is probably too wide. If you put bar stools on the other side, they would be partially sitting in the entryway/corridor and clearly seen from the entrance (which is not nice). And if you decrease width, you would have to adjust length accordingly. Now your bench is not really centrally aligned with the rest of the kitchen, although it forms a kitchen rectangle as it well aligned with the fridge wall and end of the kitchen, and once you reduce the width, rectangle will be "broken". Looking at the rest of your plan, you can also consider removing bench altogether and using the space for proper dining table/dining area, unless you already have it on top. Re: Island bench size 6Jun 26, 2020 7:07 am I actually prefer an L shape kitchen, with a smaller island that doesn't have a sink in it. If you have the opportunity to change that, you should explore. We have the L shape plus island and it works so well. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6701 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11965 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31421 |
