Browse Forums Kitchen Corner 1 Apr 07, 2020 3:29 am Hi there. I've got my kitchen benchtop joint split after 1 year. Got the cabinet makers back to fix it and after the fix it seems the benchtop is no longer straight. Is that acceptable or is there a regulation for it? Thanks in advance! Joint splitLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After fixing jointLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10970 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4589 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2637 |
