Browse Forums Kitchen Corner 1 Jan 07, 2020 10:26 pm Hi guys, My build has a walk in pantry with a size of 3m long by 1.1m wide Standard shelves are 300 deep with 4 hights are 500mm 900mm 1300mm 1700mm so first one is 500 above the floor, then 400mm gap in between ceilings are 2700mm high. so 1000mm gap from top shelf to ceiling We are thinking of adding one more shelf, which would leave a 600mm gap to the ceiling Any recommendations or idea? does the spacing seem okay? Thanks Re: Walk in Pantry shelf hights 2Jan 08, 2020 8:58 am Those heights are fine, have you thought about what you want to store on the shelves? 400 will fit a large cereal box nicely. Re: Walk in Pantry shelf hights 3Jan 08, 2020 9:33 pm Those height seem fine, and extra shelf would be good just need to mindful whatever yoi get up there wi take some effort to get down. Maybe thats why they stopped at 1700mm. MC Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Walk in Pantry shelf hights 4Jan 10, 2020 10:43 am thanks, guys! Todays the day i need to lock it in.. so I'm going crazy trying to work it out is 500 above floor good or should i go higher? I was even thinking 600, 900, 1300, 1700, then top shelf 2000 so spacing as 30,40,40,30 suggestions anyone? please Thanks! Re: Walk in Pantry shelf hights 5Jan 10, 2020 11:46 am Mine are at the builders default spacings of 500, 400, 500, 400 from the floor (with 2.7 ceiling) and it seems to work OK, I have never has a feeling I it would be better if it was different. Bottom 2 shelves are 600 deep and others 450 Re: Walk in Pantry shelf hights 7Aug 22, 2020 8:37 pm I have seen someone added continuous shelf on all 4 side of walls @ 2100mm height (above door). example is in below image top most will be above the door opening. Only issue can we less light from ceiling LED & best is to add hanging light as shown in below image. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 6650 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3802 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5191 |
