Browse Forums Kitchen Corner 1 Jul 03, 2019 5:47 pm First time I've had a ceramic cooktop. I can't work out how the controls actually work and the manual just says touch controls. I push them down hard with my finger to get them working but if it is made of glass surely they don't actually bend. And they wouldn't be like a touchscreen would they? Re: Silly question probably.... 2Jul 03, 2019 6:11 pm Ozgarden And they wouldn't be like a touchscreen would they? They are exactly like a touchscreen. You should only have to touch them lightly and for a short duration. If they don’t work that way, there may be a fault, which you should address through warranty. Re: Silly question probably.... 3Jul 03, 2019 6:30 pm Oh, okay. Thanks so much for that. Tomorrow I'll have another go. I couldn't start it originally but I was just quickly touching it. I then realised you actually have to leave your finger on a little bit longer. I am sure the stove is fine, it is the operator that is the problem. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
