Browse Forums Kitchen Corner 1 Apr 08, 2019 9:03 pm Trying to do something different with our 3m x 1.2m island bench. Looking at getting Ceasarstone Cloudburst (which I know is a bit more expensive). Currently I just have a 20mm thick waterfall on both sides. However I love the look of curved bench with a thick edge as per the image. Can anyone tell me cost differences for the stone mason to do something like this (thicker edges and circular) as opposed to straight waterfalls on both sides mitred edge? Thanks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Curved Kitchen Bench Stonetops 3Apr 21, 2019 9:37 am In general, the curve won't add a huge amount to your pricing. In the above pic, if you want 40mm or thicker and don't want a general substrate under the centre, you will have to have 2 (or more depending on the thickness you want) pieces of stone laminated the whole way through to get that thickness. This is different to a normal 40mm or larger island, where just the edge is laminated. This could easily mean you need to buy a whole other slab to make this look work. Edit: Forgot to mention, in the above pic, i'd be pretty sure that they have a steel reinforcing plate running on the underside or inside of that stone, which will bump your price. I am doing a 100mm radius curved edge on both my island and drop down table in my new build, but am still a ways off. I'm using natural New York Marble, but am doing 20mm. Will post pics in a few months though if interested. Re: Curved Kitchen Bench Stonetops 4Apr 28, 2019 9:32 pm travisaus In general, the curve won't add a huge amount to your pricing. In the above pic, if you want 40mm or thicker and don't want a general substrate under the centre, you will have to have 2 (or more depending on the thickness you want) pieces of stone laminated the whole way through to get that thickness. This is different to a normal 40mm or larger island, where just the edge is laminated. This could easily mean you need to buy a whole other slab to make this look work. Edit: Forgot to mention, in the above pic, i'd be pretty sure that they have a steel reinforcing plate running on the underside or inside of that stone, which will bump your price. I am doing a 100mm radius curved edge on both my island and drop down table in my new build, but am still a ways off. I'm using natural New York Marble, but am doing 20mm. Will post pics in a few months though if interested. Sounds like a beautiful design to me. Yes would love to see! Keep in touch! Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4930 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31266 |
