Browse Forums Kitchen Corner 1 Jan 25, 2019 6:40 pm I know I will be able to ask the kitchen supplier (when we get to that point) but would like to do some planning befroe...... Is anyone able to point me to guidelines on what size benchtop you can get from a standard size slab? and how does this change if you want a thicker egde profile? How much of the edge is wastage/unusable? thanks! Re: What size benchtop from slab? 2Jan 25, 2019 8:54 pm Slabs come in size 2.8_3 metres by 1.950 width maximum size, so some are 2.8 metres by 1.9, If your kitchen or stone guy sends you to his wholesalers factory like we did, you actually walk around and pick the actual stone you will use, you could hand pick the bigger slabs. Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12926 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 |
