well, I think it's better that you use the huggie bum wipes on your grandson than windex, LOL! Good choice
hahaha you are so right but what if I get a bit senile, it could get nasty lmao picturing senile suh spraying baby's bum with windex
Browse Forums Kitchen Corner Caesarstone benchtop advice needed please 41Mar 11, 2012 11:38 am Pete_n_Pet suh I've been using huggies botty wipes on my Corian vanity top for a quick clean, it gets all the makeup marks off I also use them to remove makeup in case you're wondering oh and now I use them on my grandson's botty too bit OT well, I think it's better that you use the huggie bum wipes on your grandson than windex, LOL! Good choice hahaha you are so right but what if I get a bit senile, it could get nasty lmao picturing senile suh spraying baby's bum with windex Re: Caesarstone benchtop advice needed please 42Mar 11, 2012 11:43 am suh Pete_n_Pet suh I've been using huggies botty wipes on my Corian vanity top for a quick clean, it gets all the makeup marks off I also use them to remove makeup in case you're wondering oh and now I use them on my grandson's botty too bit OT well, I think it's better that you use the huggie bum wipes on your grandson than windex, LOL! Good choice hahaha you are so right but what if I get a bit senile, it could get nasty lmao picturing senile suh spraying baby's bum with windex I'm sure it wouldn be a quick squirt-squirt, nothing malicious or too drenching in that. just make sure you use the clear windex, not the blue stuff 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... Re: Caesarstone benchtop advice needed please 44Mar 11, 2012 8:43 pm DOn't bother with buying the CS cleaner! A rep from CS told me same as using Jif. Re: Caesarstone benchtop advice needed please 46Sep 12, 2012 4:28 pm Cocosette HI everyone... I have a Black CS.. I washed it with normal/commun dish soap... It has lost its shine!!! how could i recover it??? please helppp!!! Maybe it's possible that there is a very thin layer of soap residue left on the bench? I'd try giving at a wipe over with metho or windex and see if that helps. try in an innocuous place first, just to be on the safe side. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7014 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12928 |
