Browse Forums Kitchen Corner 1 Nov 28, 2018 7:40 am Hi guys, we noticed in our plans we have a fixed panel under our induction cooktop- our builder refuses to allow us to change it to a drawer as “it’s the way they have always done it” even though I’ve provided them a schematic from the cooktop manufacturer showing the clearances around the cooktop will allow for a drawer. Does anyone know how much work would be involved in removing said fixed panel after handover and converting to a drawer. 900 wide x 210 deep is a lot of space to lose- but the builder won’t budge. I’ve seen a couple of examples of drawers under cooktops and it doesn’t look that complex to achieve. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks guys! Re: Fixed panel under induction cooktop- hard to change to d 2Nov 28, 2018 7:55 am Make sure you stipulate that its a removable fixed panel(for excess) Some fixed panels are exactly that, fixed and cant be removed. If the panel is fixed but easily removable you could actually use the panel as a drawer front and only need the drawer internals. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Fixed panel under induction cooktop- hard to change to d 6Nov 28, 2018 4:26 pm Correct me if I’m wrong, but that drawing is to fit a draw under the cooktop, there was another drawing showing clearances if an undermount oven were fitted. Pretty sure it’s the correct drawing- but my builder doesn’t do it that way... they either have an oven under the cooktop, or a fixed panel. Re: Fixed panel under induction cooktop- hard to change to d 7Nov 28, 2018 5:09 pm doogs82 Correct me if I’m wrong, but that drawing is to fit a draw under the cooktop, there was another drawing showing clearances if an undermount oven were fitted. Pretty sure it’s the correct drawing- but my builder doesn’t do it that way... they either have an oven under the cooktop, or a fixed panel. No, you are correct. Just get them to leave it open and get a joiner to install drawer hardware later. 5 10459 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10827 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17518 |
