Browse Forums Kitchen Corner 1 Nov 03, 2018 7:37 pm Hi, just wondering if there is an Australian standard for the size of a microwave provision? Our kitchen has been designed so the microwave sits above the oven. However, the microwave doesn't sit align with the oven once the fascia is on. The instruction booklet for the microwave says that the back needs to be open (ours isn't) and the cupboard needs to be deeper than what we have. If anyone could help or office advice that would be appreciated. Re: Help please! Microwave provision is too small 2Nov 03, 2018 7:41 pm CathyG Hi, just wondering if there is an Australian standard for the size of a microwave provision? Our kitchen has been designed so the microwave sits above the oven. However, the microwave doesn't sit align with the oven once the fascia is on. The instruction booklet for the microwave says that the back needs to be open (ours isn't) and the cupboard needs to be deeper than what we have. If anyone could help or office advice that would be appreciated. There is no standard. Usually you would provide your installation instructions to the joiner and he or she would design around those. Re: Help please! Microwave provision is too small 4Nov 05, 2018 8:06 am No standards for microwaves, they are all different sizes. But a trim kit should always be 600mm wide which is the width of most wall ovens. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Help please! Microwave provision is too small 5Jan 09, 2019 3:54 pm Actually there is no defined standards. You must provide details about space available in your kitchen to the installer. Commercial kitchen supplies is Melbourne based suppliers of all kind of kitchen equipment. https://cksonline.com.au/ Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2573 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9242 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8267 |
