Browse Forums Kitchen Corner 1 Sep 03, 2018 10:11 am Hi all, we've been looking at replacing our cabinet doors with a set of handle less ones. We've spoken to a cabinet maker about just getting the doors made and installed and they came back with a quote of 10k. Apparently they can't just replace the doors but have to remove the stone and redo the cabinets inside. Does anyone know if this is the case? We are still waiting for a few more quotes so hopefully something different comes up Re: Replacing cabinet doors with handle less 2Sep 03, 2018 10:38 am vincent2166 Apparently they can't just replace the doors but have to remove the stone and redo the cabinets inside. Does anyone know if this is the case? I'd be surprised if that was the case, but of course since you have provided no pictures we really couldn’t say. There might be something peculiar about your current kitchen installation. Re: Replacing cabinet doors with handle less 4Sep 03, 2018 1:50 pm bank Given that you lose space inside handle less drawers, I thinking it makes sense that the inside must be different? Not sure about cupboard doors though. OP only mentioned replacing cabinet doors. Re: Replacing cabinet doors with handle less 5Sep 03, 2018 10:43 pm Hi Vincent. When you say handle less do you mean push to open or recessed finger pulls/ sharknose. Push to open is a cheap option as it's simply new doors and some hardware changes but the recessed finger pulls or sharknose requires modification of the carcass and will be expensive. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Replacing cabinet doors with handle less 6Sep 11, 2018 2:47 pm arcadelt vincent2166 Apparently they can't just replace the doors but have to remove the stone and redo the cabinets inside. Does anyone know if this is the case? I'd be surprised if that was the case, but of course since you have provided no pictures we really couldn’t say. There might be something peculiar about your current kitchen installation. If they are talking about the standard sharknose handleless doors and drawers then it is most certainly the case! Sharknose doors and drawers have a 50mm polyurethane rail cut into the cabinet edges to cover the gap created by the finger space. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Replacing cabinet doors with handle less 7Sep 11, 2018 8:22 pm Blum tip on tandem drawers and push catch doors for floor cabinets (10mm under hang on over heads) is the cheapest way around this. As some users have said, shark nose profile handles will require alterations to the cabinetry which will make the whole job pointless to renovate as it would be much more cost efficient to get a brand new kitchen. 10k is bloody steep btw. Re: Replacing cabinet doors with handle less 8Sep 29, 2018 8:31 am To avoid touching the carcass, another option is to integrated the finger pull into the fronts. Example of this : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61346 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6346 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 |
