Browse Forums Kitchen Corner Re: Low ceiling and pendant lights 3Aug 21, 2018 11:45 am Surely OP means 2.4m. If it’s above the island and has the prescribed distance between bench top and pendant I don’t see a problem with it, no one should be bumping their head on the pendant. Can’t remember what the recommended distance between pendants and bench tops - is it 70-90cm? So assuming a bench top of 90cm, that still leaves a min of 60cm from ceiling to base of pendant. Re: Low ceiling and pendant lights 5Aug 21, 2018 11:52 am arcadelt Hillsbuilds Surely OP means 2.4m. ...or 1.4m above the bench top, so perhaps 2.3ish? One never knows on these forums what someone means. Good point! Low ceiling and pendant lights 8Aug 21, 2018 2:42 pm MAspinall Oops, meant 2.4m. I think Hillsbuilds has given a good answer. All I would add is that how it looks will depend on the height and width of your pendant lights. Also, make sure to check the spread of light at various heights, as a narrow cast will look like a spotlight at a lower hang and not serve the purpose of task lighting the bench top. 4 6194 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17525 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13735 |
