Waterfall on island bench
We’re putting one in. To me it makes the kitchen look more grand.
Is it possible to put a powerpoint in the Caesarstone (silestone) waterfall edge in the kitchen island bench? We had our electrical appointment with Metricon yesterday and they are adamant that they can't cut into the caesarstone so it would be mounted to the front of the laminate cupboard of the island bench but I'm sure I have seen it done before. Any help would be appreciated.
Ask your stone mason. They do the cutouts for your sink and cooktop so they are the ones who will do that. It can be done as I have recently installed a kitchen which had it done.
Thanks Choppy182
Just need to think of the practicality of the location of the GPO.
Is putting it on the side the best spot for it (eg, cables hanging in a walk way)
Is this the best spot aesthetically for it?
I don't think of Waterfall ends as a trend - they've been done since the late 90's. Moreso a feature on the ends of your floor cabinetry, especially if you have a nice bench material, and it's a visual end from other areas (eg entrances, decks etc).
As mentioned above. A GPO in the Waterfall end isn't too dissimilar to asking for a sink cutout, or a tap hole. It's pretty common. Should be under $200 to have this penetration made in the surface.
Thanks for your reply GBDesign.
The GPO is needed in the island bench as that is where I do most of my meal prep & cooking. I will also be doing cooking classes in my kitchen so need to use appliances on the island bench. I don’t plan to have appliances plugged in all the time.
In regard to aesthetics, it will be on a side that is not seen when walking into the open plan living area.
I have found a few people who are building/ have built with Metricon & they have been able to do it so I will follow this up with them on Monday.
Whereas the more common power points don't need such a big hole and are more tollerant of any variations.
I kind of got caught with this in my place, though it was in the glass splash back no an island. The sparky had to enlarge the hole to fit my power points (Clipsal Saturn Zen). Lets say he was very worried that he might crack the glass! But he got there in the end.
If you have cupboard doors you can mount it on the inside wall. If you have drawers you can have a false drawer front which flips down to reveal a bank of power points behind it.
3
Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or…
30/06/2023
2
Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the…
31/01/2024
12
These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is…
