Browse Forums Kitchen Corner Re: Kitchen island with floating floor? 2Jul 23, 2018 11:49 am seechange How do you finish it without using scotia? Anyone have photos they are willing to share Do a search in this forum, this was discussed approximately 6 months ago and I put up some detailed info on how to do this. Its quite easy but needs to be allowed for. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen island with floating floor? 3Jul 23, 2018 3:39 pm CuttingEdgeKitchens seechange How do you finish it without using scotia? Anyone have photos they are willing to share Do a search in this forum, this was discussed approximately 6 months ago and I put up some detailed info on how to do this. Its quite easy but needs to be allowed for. Thanks! I did try searching before I posted but could only find the post that applied to waterfall bench tops - is that the one you are referring to? We are having shaker style cabinets so no waterfall. I guess an option is to have kickboards all the way around? Or can you take the same approach as you discussed with the waterfalls when it comes to the end panels on the island? Re: Kitchen island with floating floor? 4Jul 23, 2018 5:28 pm seechange CuttingEdgeKitchens seechange How do you finish it without using scotia? Anyone have photos they are willing to share Do a search in this forum, this was discussed approximately 6 months ago and I put up some detailed info on how to do this. Its quite easy but needs to be allowed for. Thanks! I did try searching before I posted but could only find the post that applied to waterfall bench tops - is that the one you are referring to? We are having shaker style cabinets so no waterfall. I guess an option is to have kickboards all the way around? Or can you take the same approach as you discussed with the waterfalls when it comes to the end panels on the island? Pretty much the same process. Install kitchen before floor goes down leaving panels to floor off. Install floor Install false kickboards and panels over the new floor Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen island with floating floor? 5Aug 05, 2018 9:03 pm CuttingEdgeKitchens Pretty much the same process. Install kitchen before floor goes down leaving panels to floor off. Install floor Install false kickboards and panels over the new floor how do you do your finished fridge panel when its on the open end as you cant fix it to the floating floor? Re: Kitchen island with floating floor? 6Aug 06, 2018 7:25 am Jonnii98 CuttingEdgeKitchens Pretty much the same process. Install kitchen before floor goes down leaving panels to floor off. Install floor Install false kickboards and panels over the new floor how do you do your finished fridge panel when its on the open end as you cant fix it to the floating floor? The fridge panel is left off and fitted after the floor has been installed. The panel is screwed to the floor using two small brackets. There is no issue with this at all. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3110 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 425 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6238 |
