Browse Forums Kitchen Corner 1 Jun 13, 2018 4:17 pm Hi Guys, Need help choosing the correct size pendant light for my island bench. The island bench is 3m long & 90cm deep. The pendants I've found come in a 35cm diameter & a 45cm diameter. I am only wanting two pendants. Originally I was going to go with the smaller one, as I don't want them to look 'cluttered'. However, I'm wondering whether they'll look too small for the length of the bench? I should also mention that our ceilings are only standard 2.4m which is another reason I was leaning towards the smaller size. Any help would be appreciated! Pendant light help! 2Jun 14, 2018 7:42 am Hey Jen, that bench is a decent length! I reckon you can get away with the larger pendants. Just depends if you want them to be statement pieces or not. Don’t think they would be too cluttered as you could space them roughly 70cm apart for an even gap between them and the ends. But you’d want to make sure they don’t hang too low. Re: Pendant light help! 3Jun 21, 2018 8:33 am We used Alfred from Beacon. Our Island is 3.0m x 1.2m - https://www.beaconlighting.com.au/alfred-1-light-pendant-in-black.html Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pendant light help! 4Jul 18, 2018 4:11 pm colin1, what distance between your benchtop and the bottom of the pendants? Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11692 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17353 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19978 |
