Browse Forums Kitchen Corner 1 Jun 03, 2018 7:10 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Waterfall edges after handover? 3Jun 04, 2018 8:34 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Waterfall edges after handover? 5Jun 04, 2018 7:18 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Waterfall edges after handover? 6Jun 04, 2018 7:22 pm InvincibleInDN aphsta You can do them with a shadow-line joint instead. You’d need the ends to have a 20mm overhang I just had temporary bench tops with my build and am getting natural granite and marble for less than the builders price for manufactured stone after handover I like the idea of having a temporary bench top and replace with the one we wanted. Do they installed the waterfall over the tiles? We are doing our own vinyl planks after handover. We’ll have the stone done first so it can be laid on the hard surface. Re: Waterfall edges after handover? 7Jun 23, 2018 4:30 pm InvincibleInDN aphsta You can do them with a shadow-line joint instead. You’d need the ends to have a 20mm overhang I just had temporary bench tops with my build and am getting natural granite and marble for less than the builders price for manufactured stone after handover I like the idea of having a temporary bench top and replace with the one we wanted. Do they installed the waterfall over the tiles? You can sit them on tile not a problem yes it does, you've just not understood it. theres a difference. 4 5332 Your house should come in "as new" condition. It should be clean, and without stains 1 4566 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37158 |
