Browse Forums Kitchen Corner 1 Apr 27, 2018 9:54 am Hi everyone, We are about to start designing all the cabinetry for our new home. We have a butler's pantry with three areas for cabinets, and my thoughts were cupboards and overheads to two areas, and the third to be all open shelving. I just want to hear from people who have done this, how practical it really is, with dust/keeping it looking clean etc. We had a walk in pantry previously and had no issues, but in a bigger area with no door, I'm a little concerned. Have attached pictures of what we are wanting. Would love to hear everyone's thoughts! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1st build: viewtopic.php?f=31&t=59376 *New*-2nd build: viewtopic.php?f=31&t=70324&p=1154282#p1154282 Open pantry shelving 2Apr 27, 2018 10:06 am stellabella Would love to hear everyone's thoughts! We are just installing our scullery joinery now (I mean right now). You can save money with open shelving as you save on panelling and door hardware. However, the shelves in your second picture might be weight limited as the will sag over time due to the long unsupported span. As for cleaning, my thoughts are that this is a utility area and any dirt/dust/mess here will save dirt/dust/mess in more public areas, so is worth any compromise. Re: Open pantry shelving 3Apr 27, 2018 9:01 pm My butlers pantry is 3.6x1.8m and I plan on using one of the long walls for floor to ceiling shelving. No-one has mentioned it being a problem when I have discussed it viewtopic.php?f=31&t=89059 Open pantry shelving 4Apr 28, 2018 11:07 am aphsta My butlers pantry is 3.6x1.8m and I plan on using one of the long walls for floor to ceiling shelving. No-one has mentioned it being a problem when I have discussed it If you are planning on having joinery span 3.6m without any vertical bracing (external or internal to the wall) I would consider explicitly discussing the risk of sag with your joiner. Re: Open pantry shelving 5May 05, 2018 11:41 pm arcadelt aphsta My butlers pantry is 3.6x1.8m and I plan on using one of the long walls for floor to ceiling shelving. No-one has mentioned it being a problem when I have discussed it If you are planning on having joinery span 3.6m without any vertical bracing (external or internal to the wall) I would consider explicitly discussing the risk of sag with your joiner. The wall of the side the shelving is on is less than 3000mm as the entry door to the pantry is on that wall. Also, the short wall without the window at the far end is going to have a 600mm bench coming out from that wall which will reduce the length of wall the shelving will be able to be on by that amount so it’s going to be just over 2m I think by the time we are done. viewtopic.php?f=31&t=89059 Re: Open pantry shelving 6May 06, 2018 10:15 am aphsta ...so it’s going to be just over 2m I think by the time we are done. For the record, my joiner is wary of spanning 16mm laminate more than 1m without a support due to sag over time. Maybe he is over cautious - maybe not. YMMV, so I suggest you talk to your joiner. Re: Open pantry shelving 7May 09, 2018 4:42 pm arcadelt aphsta ...so it’s going to be just over 2m I think by the time we are done. For the record, my joiner is wary of spanning 16mm laminate more than 1m without a support due to sag over time. Maybe he is over cautious - maybe not. YMMV, so I suggest you talk to your joiner. I actually dont like spaning any more than 800mm! At anything over 700mm I put a centre shelf pin in the back of the cabinet and suggest anything over 900 be fixed or have a 40mm vertical strengthening rail under the front edge. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4194 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5215 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44079 |
