Browse Forums Kitchen Corner 1 Apr 04, 2018 10:13 pm Hello, example out door kitchen: https://www.barbequesgalore.com.au/discoverer-island-bbq-range-sink-shelves How do you get water to them, do you need to install a water point similar to the fridge ones and does it need to be done by builder? Re: Outdoor kitchens question 2Apr 04, 2018 10:39 pm pandibabi How do you get water to them, do you need to install a water point similar to the fridge ones and does it need to be done by builder? If you check the instruction manual it just leaves the water inlet and drain hanging, and says nothing about how you connect it. However, because the BBQ has wheels, you wouldn’t want a permanent connection anyway, so you would probably rig it up like you would a machine machine, with a hot and cold tap, plus a drain outlet nearby. I would suggest that your plumber would need to run a hot and cold water line and taps and a drain to your patio area and then you would attach the BBQ to those yourself. Of course, if you want to dispense with the fuss, you could just use a garden hose to the cold water, dispense with hot water and just run the drain through a flexible pipe to a point in the garden. "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1565 Thanks for letting us know. The programmer will have a look at this later today. 2 6682 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29607 |
