Browse Forums Kitchen Corner 1 Feb 11, 2018 2:20 pm Floating floor and stone waterfalls have always been an issue! No one likes Scotia around their stone. I found this photo and know that this can be done, you just need to find the right installer to help you with this problem. Good luck.... press on, and don't settle for less. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating Floors and Waterfalls 2Feb 13, 2018 8:43 am That is defiantly an option but there is a better way but you need a kitchen company that knows what they are doing! When I do waterfalls to floating floors I do the following. I start by building a proper kickboard (no plastic legs) out of waterproof plywood. Think a ladder style kickboard. This kickboard is securely screwed to the subfloor. Cabinets are then fitted. No stone or kickboard faces have been installed at this point. Floating floor is now installed. At this point the stone is measured up. A small 2mm gap is allowed between the bottom of the waterfall and the floating floor. When the stone is installed the waterfalls are glued to the cabinetry and then a tiny silicon join is run between them and the floor. Kickboard faces are now installed. This method allows for a completely seamless look with no mouldings at all. The entire weight of the stone is supported by the kickboards and cabinets. I have done this a number of times now and it has worked every time. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating Floors and Waterfalls 3Feb 13, 2018 12:35 pm Very nice, good reply! 😊 Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating Floors and Waterfalls 4Feb 14, 2018 11:38 am CuttingEdgeKitchens That is defiantly an option but there is a better way but you need a kitchen company that knows what they are doing! When I do waterfalls to floating floors I do the following. I start by building a proper kickboard (no plastic legs) out of waterproof plywood. Think a ladder style kickboard. This kickboard is securely screwed to the subfloor. Cabinets are then fitted. No stone or kickboard faces have been installed at this point. Floating floor is now installed. At this point the stone is measured up. A small 2mm gap is allowed between the bottom of the waterfall and the floating floor. When the stone is installed the waterfalls are glued to the cabinetry and then a tiny silicon join is run between them and the floor. Kickboard faces are now installed. This method allows for a completely seamless look with no mouldings at all. The entire weight of the stone is supported by the kickboards and cabinets. I have done this a number of times now and it has worked every time. Re: Floating Floors and Waterfalls 5Feb 14, 2018 11:58 am I'd love to see a photo also. Thank you. 😊 Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating Floors and Waterfalls 6Feb 17, 2018 1:36 pm This is one I did a few years ago. The pick doesn't show much other than clean lines and no mouldings! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating Floors and Waterfalls 8Feb 17, 2018 5:45 pm Re: Floating Floors and Waterfalls 9Feb 20, 2018 4:39 pm Joker Really high quality work, that would be lost forever if all builds were only done by the volume boys. Its crazy the what passes for a kitchen when build be these guys. They just don't care. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Floating Floors and Waterfalls 10Mar 23, 2018 7:08 am Aaron Master Stonemason <!-- w --><a class="postlink" href="http://www.stonebenchtopcleaner.com.au">www.stonebenchtopcleaner.com.au</a><!-- w --> Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6828 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3534 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1311 |
