Browse Forums Kitchen Corner 1 Dec 21, 2017 9:14 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had in our original plans that we wanted a large pull out spice rack. The Kitchen company says that don't use them anymore as they go out of alignment eventually.Thay want to instead put in 400mm pantry with inner drawers. I am not worried but the other half wanted the pull out rack. I think individual drawers will probably hold weight better as each draw will have its own runner where the pull out rach is only supported on the top and bottom. Any thoughts greatly appreciated. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pull Out Spice Rack - Kitchen Designer says No 2Dec 26, 2017 12:31 pm I think you and the designer have the better idea here. Like you say, if the individual pull out drawers will last longer and have similar ease of access as the big pull out spice rack it makes sense to go with that. If the single rack is going to go off the rails after a period of time that would be super frustrating. What was it about the single pull out rack your partner liked? Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 Your build is relatively simple, I believe your job can be easily done by a good building designer, you really do not need to pay for the architect. Remember, architect's… 3 10986 4 14294 |
