Browse Forums Kitchen Corner 1 Sep 06, 2017 2:07 pm Hi there, I have laminate kitchen cabinet doors that I'm considering painting with chalkboard paint. I can see a challenge in getting the paint to adhere well to such a smooth surface. My first thoughts are to remove the doors, then clean, sand, prime and paint. Is this project feasible? If so, then any how-to advice would be appreciated and so would recommendations on the type of paint I should use. Thanks Re: Painting kitchen cabinets with chalkboard paint? 2Sep 06, 2017 5:09 pm mattski86 Hi there, I have laminate kitchen cabinet doors that I'm considering painting with chalkboard paint. I can see a challenge in getting the paint to adhere well to such a smooth surface. My first thoughts are to remove the doors, then clean, sand, prime and paint. Is this project feasible? If so, then any how-to advice would be appreciated and so would recommendations on the type of paint I should use. Thanks As long as you key the surface by sanding it properly the undercoat/paint will stick easily. Why chalk board paint? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 6635 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 30511 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 3784 |
