Browse Forums Kitchen Corner Re: Electric v Gas cooktop? 3Sep 01, 2017 10:02 pm Yup, induction! Once you've tried it you're never going back to either gas or (non-induction) electric... Re: Electric v Gas cooktop? 5Sep 04, 2017 12:26 pm Induction Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Electric v Gas cooktop? 6Mar 17, 2018 8:03 pm Induction, love it. I would stay away from gas just based on the price of gas. Re: Electric v Gas cooktop? 7Mar 19, 2018 11:09 pm Induction. Quick, controlled, easy to clean and the flat surface can be used as a bench when not in use. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Electric v Gas cooktop? 8Apr 04, 2018 9:15 am Induction but you have to check the wattage of the zones and take one with dual or better multislider. Until recently I had Miele. With various wattages per zone, it was easy to control. The bad thing about the cooktop was that it had + and - sensors to go up and down with the temperature. That is anoyingbecause you have to tap, tap an tap. The other thing tht drove me razy was, that the sensor didn't respond when my fingers were wet or oily. Because I expected overseas visitors, I needed a new cooktop pronto. I bought the cheapest I could find, that was a Delonghi. Well, it has a slider, that'good, the rest is bad. Because it is an older display model, it has older generation of induction coils. It does work as well as my Miele, 2 of the large zones have identical wattage, the change in temperature is not as good as with th Mile. If I cooked pasta, I started with 9, went back to 8. Now, I start with 9, go back to 8, mostly to high, go back to 7, often too little. What I try to say, it is a bit you get what you pay for. Good are Neff induction cooktop with twistpad. However, the new twistpad fire doesn't work as good as the old one, it is one more step when changing temperature. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2778 I’d go heat pump, efficient and you can have a large storage tank so you don’t run out. If the house is big it can take a while for the water to run hot. I was lucky… 1 309 |
