Browse Forums Kitchen Corner Re: Distance between island bench and wall cabinets in kitch 2Jun 19, 2017 9:43 pm Ezza78 Is there a standard amount of space between island bench and wall cabinets? Just noticed ours is at a metre and wondering if that's enough? Coral homes Modified Stradbroke 29 weeks Milestone coral homes modified stradebroke 32 Re: Distance between island bench and wall cabinets in kitch 3Jun 19, 2017 9:59 pm This might help https://en.wikipedia.org/wiki/Kitchen_work_triangle Saying that, i've been to a lot of display houses. The space between the back bench and the kitchen island varies between 1.1m to 1.3m depending on the design, maybe a bit more for those U-shaped kitchens. On Arden's Beaumont and Votivo, I believe it's 1.1m. I didn't find it too small, and I am fussy with my kitchen. I think the best way is to go to a display home and try it out yourself. Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 Re: Distance between island bench and wall cabinets in kitch 6Jun 19, 2017 11:39 pm Ezza78 Is there a standard amount of space between island bench and wall cabinets? Just noticed ours is at a metre and wondering if that's enough? Ours is 1.2m Re: Distance between island bench and wall cabinets in kitch 7Jun 20, 2017 1:05 am Ours is 1300 if measured from kickboard to kickboard, 1200 if between the edge of both benchtops. Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Distance between island bench and wall cabinets in kitch 8Jun 20, 2017 7:09 am Thanks for the photo! That's a good amount of space! Re: Distance between island bench and wall cabinets in kitch 9Jun 20, 2017 7:11 am g33kerb0t This might help https://en.wikipedia.org/wiki/Kitchen_work_triangle Saying that, i've been to a lot of display houses. The space between the back bench and the kitchen island varies between 1.1m to 1.3m depending on the design, maybe a bit more for those U-shaped kitchens. On Arden's Beaumont and Votivo, I believe it's 1.1m. I didn't find it too small, and I am fussy with my kitchen. I think the best way is to go to a display home and try it out yourself. Yeah I measured wrong, it's 1.1m but light increase to 1.2. Thanks. Hadn't noticed it too small in the displays got Arden. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9948 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39469 2 7484 |
