Browse Forums Kitchen Corner 1 Mar 13, 2017 5:47 pm Does anyone know the general standard builders range in any project home company for silestone, i know that builders ranges will vary but it will give me an idea of what is included. Thanks Re: Standard builders range of silestone 2Mar 19, 2017 5:07 pm Unfortunately its totally different from one company to the next. Who are you building with? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Standard builders range of silestone 3Mar 13, 2018 11:13 am There is generally 8 colours in the standard range that is the budget range available to builders You will need to contact your specific builder, as not all builders have signed up for that deal and will depend on the arrangements etc Aaron Master Stonemason <!-- w --><a class="postlink" href="http://www.stonebenchtopcleaner.com.au">www.stonebenchtopcleaner.com.au</a><!-- w --> What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2574 Look at your bill from the electricity company. It should detail the charges. You will need to do some estimating and some calculations. Then charge the… 8 4250 Site works are just about to start on our build with Blueprint in Midvale. viewtopic.php?f=31&t=106894 2 3957 |
