Browse Forums Kitchen Corner 1 Jun 24, 2016 6:57 pm Hello, I just signed contracts today on a property which has normal laminate benchtops. I would like to change them over to stone as soon as I get in. Just wondering if you could recommend some installers in Sydney. Also, could you please help me to understand the benefits of 20mm vs 40mm vs 80mm etc? Someone said just go with the 20mm as anything more will cause the cabinets to wear down quicker? Whats your thoughts / suggestions? Re: [SYD] Stone benchtop replacement recommended installers/ 2Jun 25, 2016 10:32 am joshuah Also, could you please help me to understand the benefits of 20mm vs 40mm vs 80mm etc? Someone said just go with the 20mm as anything more will cause the cabinets to wear down quicker? Whats your thoughts / suggestions? No difference other than aesthetic. 40mm is just 20mm with a mitred 40mm front edge, 80mm is just 20mm with a mitred 80mm front edge. Who ever told you the cabinets will "wear down quicker" is an oxygen thief and has absolutely no idea! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12929 Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 |
