Hi,
Has anyone ever done DIY polished cement benchtops? If so what mixture did you use? Any tips? Any pics?
Thanks
Browse Forums Kitchen Corner Re: cement benchtop 2Jun 04, 2016 8:04 am Never heard of it - but that means little ... Might be quite nice. Re: cement benchtop 3Jun 04, 2016 8:40 am I have had customers make there own cement tops, I would recommend against it. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4600 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3227 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12934 |
