Browse Forums Kitchen Corner Re: melamine grain direction 2Apr 18, 2016 12:05 am Grain looks better vertical because it is very hard to get all the grain on the cupboards to match nicely, and may cost extra to have it horizontal. I wanted hotizontal but our builder showed us a pic from a client's home and it looked terrible. Re: melamine grain direction 3Apr 18, 2016 7:30 am Nyan Grain looks better vertical because it is very hard to get all the grain on the cupboards to match nicely, and may cost extra to have it horizontal. I wanted hotizontal but our builder showed us a pic from a client's home and it looked terrible. That really depends on the length of the panel! If the panel is 2400mm or less then it doesn't make any difference to have it either direction, it only comes down to personal preference. If the panel is over 2400mm then vertical grain is far better as it joins up without standing out. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: melamine grain direction 4Apr 18, 2016 7:39 am If you go vertical, as nyan and CEK said make sure that either the sheet is long enough or that you have it documented in your contract that all panels will line up. I've seen photos of a few kitchens where it doesn't align and it looks pretty bad M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: melamine grain direction 5Apr 18, 2016 8:29 am MrsJM If you go vertical, as nyan and CEK said make sure that either the sheet is long enough or that you have it documented in your contract that all panels will line up. I've seen photos of a few kitchens where it doesn't align and it looks pretty bad If you join sheets end on its almost impossible to get the grain to line up. I just wouldn't do it! If your bar panel is longer than the max length of the material available then the grain should go vertically. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: melamine grain direction 6Apr 30, 2016 12:57 pm MrsJM could you please explain what you mean? if i go vertical then lining up doesn't matter for 'Rocco Lini' as Nyan and CEK suggested I would think. I just received my kitchen plans and the front island is 3 metres. They have it in 3 panels so it appears the grain is vertical. Should I go 2 panels with horizontal grain? This is the colour. It looks like sheen only comes in 2400 x 1200 lengths. https://www.polytec.com.au/colour/rocco ... lini-sheen I'm just a single clueless guy so i appreciate your opinion on what will look best. Whatever the grain direction on the front island, I will do the same to my top cupboards. Thanks for any advice. Re: melamine grain direction 7Apr 30, 2016 1:51 pm poseiden I just received my kitchen plans and the front island is 3 metres. They have it in 3 panels so it appears the grain is vertical. Should I go 2 panels with horizontal grain? This is the colour. It looks like sheen only comes in 2400 x 1200 lengths. https://www.polytec.com.au/colour/rocco ... lini-sheen I'm just a single clueless guy so i appreciate your opinion on what will look best. Whatever the grain direction on the front island, I will do the same to my top cupboards. Thanks for any advice. Timber grain joins well for a bar back with the grain running vertically. It doesn't work well at all the other way!! Yours is fine! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31816 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 |
