Browse Forums Kitchen Corner 1 Mar 11, 2016 10:55 pm Before I go out and get some quotes I was hoping for a bit of guidance from you guys on possible options for getting stone benchtops in my kitchen. I've attached a pic below of what the kitchen currently looks like. The benchtops are just gloss white laminate, and while they're perfectly fine I want the slightly upmarket feel of stone. I want to keep everything the same (colour, waterfall edges on island), just convert it to stone. What will be the most cost-effective approach? I don't have preference between natural or engineered stone, just as long as it's a nice white colour. Are those stone overlays that make use of the existing benchtops any good? Cheers for any advice you can offer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice on changing from laminate bechtops to stone 2Mar 15, 2016 12:25 am It's highly likely you'll need to change the splashback as well. Seems like an expensive excersice to change a white square edge for a white square edge? My advice is to spend that money on an area that will actually add value. Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Advice on changing from laminate bechtops to stone 3Mar 15, 2016 1:21 pm Max_Power Are those stone overlays that make use of the existing benchtops any good? l] NOOOOOOOOOOOO Its not a cheap exercise to swap over to stone. Your looking at around 4-5k or more for the stone/waterfalls depending on which colour you go for you then also need a plumber and electrician to do a disconnect and reconnect and you might also be up for a new splashback if it gets damaged when the old top comes out. Depending on the colour you choose I would say minimum you are looking at is around 6k but it could be more! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Advice on changing from laminate bechtops to stone 4Mar 18, 2016 7:24 pm Have to say your existing kitchen looks fantastic. I couldn't tell from a picture that that isn't a stone benchtop . Good luck with the changes, I have no knowledge of those things so can't help. Re: Advice on changing from laminate bechtops to stone 6Mar 21, 2016 1:49 am Granite transformations could still damage splash back unfortunately. Sorry why again do you want to change the bench? You said in your op you want an upmarket feel, but from the pic you haVE that already. Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Advice on changing from laminate bechtops to stone 7Mar 21, 2016 7:01 am I would rather have a nice holiday than go the stone look. We have got stone at the place we are currently renting and I'm not that keen. . . . it's noisy and unforgiving of cups and glasses if you are a little bit clumsy. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Advice on changing from laminate bechtops to stone 9Mar 27, 2016 8:26 pm Can I say you kitchen is so amazingly clean, wow. Good luck with the stone. Re: Advice on changing from laminate bechtops to stone 10Apr 25, 2016 7:08 pm I think stone is the laminate of the noughties. Caesarstone is in McDonalds. Your kitchen looks good, so I'd leave it. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11915 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5536 |
