Browse Forums Kitchen Corner Re: Cupboard Surfaces - Laminate, Polyurethane, Vinal Wrap?????? 15Jul 23, 2008 7:53 pm The actual finished surface of a satin polyurethane is far smoother than a similar lustre in melamine board, which is what seems to make the marks show up more on two pack than board.
Similarly there is an observable difference between thermolaminate and polyurethane. Two pack is still a top finish though, and I would put it in my environment if I wanted doors. Cheers, Earl Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3043 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11254 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17009 |
