Browse Forums Kitchen Corner 1 Jul 23, 2016 6:33 am Building a house at the moment and thinking of getting a Whispair Monte Carlo 2010 m3/hr rangehood (http://www.whispair.com.au/#!monte-carl ... 09s3/c15fe) and a Highland 98.5cm 6 burners gas cooktop (http://media.wix.com/ugd/d71382_ab9ec03 ... 1cc7e0.pdf). The reason for picking the 300mm deep rangehood is to give the kitchen a seamless look. I do do some heavy cookings at times. Im wondering if the 300mm deep undermount rangehood is sufficient to extract smokes and odours, given the cooktop is much deeper and slightly wider than the rangehood. Can anyone with a standard depth (300mm) undermount rangehood with a standard depth (600mm) cooktop comment on this? Will it work? Thanks. Re: Is a standard depth (300mm) undermount rangehood enough? 2Jul 25, 2016 8:30 am Persimmon Can anyone with a standard depth (300mm) undermount rangehood with a standard depth (600mm) cooktop comment on this? Will it work? Thanks. The vast majority of kitchens these days have exactly what you are talking about. I have it in my home and don't have an issue. You just need to make sure you have a rangehood with decent extraction. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9750 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5745 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 586 |
