Browse Forums Kitchen Corner 1 Jan 19, 2016 7:02 pm Hey guys, My original selection for kitchen cabinetry was formica gloss graphite. I have since been told that it is discontinued and my choices are to either stick with this in a matt finish or to re-select. Is it possible to paint on a high-gloss clear acrylic varnish after handover and will I still get the same effect? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My build with FHBD viewtopic.php?f=31&t=78344 Re: Painting a gloss finish onto matt cabinetry??? 3Jan 20, 2016 11:16 am Hey Daz, I've worked in the painting industry so you can paint virtually any surface if it's prepared properly. The issue you have is the finish won't look like the smooth glossy grey you're wanting to achieve. If you use a brush you'll have streaks, if you use the mohair roller (recommended for enamels), it will look better but not as smooth as the pic above. If you wanted to use a clear varnish I don't think it would work because you need to sans the surface back to get some "grip". And you'd see the sanding on the laminate through the gloss varnish. Our Easystart Build in Annie's Landing https://forum.homeone.com.au/viewtopic.php?f=31&t=81061&p=1478674#p1478674 Re: Painting a gloss finish onto matt cabinetry??? 4Jan 20, 2016 9:05 pm Thanks for the info Chantal I guess its onto plan B then hahaha My build with FHBD viewtopic.php?f=31&t=78344 Re: Painting a gloss finish onto matt cabinetry??? 5Jan 21, 2016 4:33 pm As mentioned above, yes its possibly but I wouldn't do it. You will end up with a cheap looking kitchen with problems! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Painting a gloss finish onto matt cabinetry??? 6Jan 22, 2016 12:28 am Wow! What ever u have a beautiful kitchen I asked this question of one of the forum's resident cabinet makers who may/may not wish to identify himself to answer other questions if he sees this, but the rersponse… 3 7683 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6678 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18112 |
