Browse Forums Kitchen Corner 1 Nov 13, 2015 2:34 pm I had my Caesarstone installed a couple days ago and have a gap between the benchtop and cabinet below. It looks huge when I stare at it for 15 minutes but it's only 2mm. I tried to find pictures of the underside of stone benchtop installs but unsurprisingly they're not many floating around. I'm wondering if this is normal and nothing to worry about or if it could lead to cracking in the future. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Benchtop gap 2Nov 13, 2015 3:50 pm Do you have a straight edge? Sit something straight on the bench top to work out if the top is bowed or the cabinets out of level. Either way I cant see it being much of a problem. A tube of white no more gaps will solve the problem! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Benchtop gap 4Nov 17, 2015 9:24 am Sammy2000 Thanks for that. My first time building a kitchen and every 1mm looks like 10mm to me at the moment. The gap would correlate to the thickness of the adhesive they have used to secure the stone. You will never get a zero gap. As Cutting edge said, some no more gaps or silastic will do the trick to fill the gap, or just leave it. You will only ever see it if you are on your hands and knees looking for it. If you have a new house, suggest you don't go looking for every little 'fault' because you will go mad. There will be gaps and imperfections even with the best of builders. You need to stand back and look and anything that is obvious from a distance needs fixing, but not everything that looks 'wrong' at 30cm, like this gap if a problem. Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4870 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19080 2 7482 |
