Browse Forums Kitchen Corner 1 Sep 19, 2015 9:23 pm Hi there, I have purchased an old Rayburn no3 combustion stove I have found the original documents regarding installation but it assumes that you are putting it into a fireplace or similar as the old houses had a kitchen nook. I want to put it against a besser block wall so should be no problem there but I have also bought a gas stove that I would like to put next to it. How much gap do you recon I should have? (Given that the gas stove is unlikely to be combustible.) Cheers Vicki Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1892 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3775 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 6976 |
