Browse Forums Kitchen Corner 1 Aug 17, 2015 1:14 am Hi, We are building with Eden Brae and currently going through the color selection and kitchen appointment stage. After having spent lot of time on kitchen combination we finalized the following two combinations. 1. Essastone Crystal Chalk + Formica Mocha Firwood - Gloss finish 2. Essastone Macchiato + Laminex Espresso Ligna - Silk finis Please advice which one will look better. Thanks, Adnan Re: Kitchen combination advice 5Sep 09, 2015 9:15 am I prefer option 1 because of its stronger colour contrast. Also, your kitchen will look brighter and more cheerful. It'll be however better if you can post some images so I can visualise better. Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3272 2 10948 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18027 |
