Browse Forums Kitchen Corner Re: Handleless Kitchens - Advice 21Jul 15, 2015 9:45 pm If you get the chance go for the finger pull lift up for overhead cupboards. The 2 doors are lifted lightly upwards together & then close slowly down together. Clean, clever design. My builder incorrectly installed the push open for overheads , SS said that these were the only uplifting doors available! Ha ha ha NO it's not. Luckily all changed, loved them in my old & new kitchen, well worth the $900 VO. "is it exempt or do I need to get permission from council" Call your Council and ask them 1 1583 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18323 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
