Browse Forums Kitchen Corner Re: Above or below sink? Pull out shelf for microwave? 3Jun 26, 2015 8:17 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Above or below sink? Pull out shelf for microwave? 9Jun 26, 2015 10:46 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Above or below sink? Pull out shelf for microwave? 11Jun 27, 2015 5:24 pm Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Above or below sink? Pull out shelf for microwave? 16Jul 08, 2015 6:34 am Quote: They work well above an oven in a tower, BUT then you are stuck with a 600mm oven. If you like to cook this can be a problem We ended up deciding on a 600 tower and a 900 under bench oven partly for this reason After going around and around it seemed like the best.. though decadent option! A double oven would have made the micro too high for me,under bench too low for him...we'll be doing christmas dinners I think! Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6355 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20616 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 |
