Browse Forums Kitchen Corner 1 May 10, 2015 9:00 pm Well, I've picked the gas cooker that I would like but it needs to be installed on a benchtop that has a granite transformation layer over the laminate benchtop (chosen by previous owner). The cut out on the old electric cooktop is quite small 550w 460d and most gas cookers have a cutout depth that is 20-30mm larger. The width seems fine. Can we trim the cut out to accommodate the larger cooktop or would this completely stuff the bench? Could we tape it and get out the jigsaw or is this just a can of worms best kept shut and I should just deal with a crappy cooker for the time being. Thanks for any advice.... Re: Trimming a benchtop that has been granite transformed 2May 11, 2015 7:35 am What material is on the top?? Is it Granite, caesarstone or a soft material like corian?? I would be cutting the thickness off the stone with a diamond blade and angle grinder then cutting the timber part of the top with a jigsaw! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Trimming a benchtop that has been granite transformed 3May 12, 2015 8:45 am The material is a thin layer of caesarstone. Re: Trimming a benchtop that has been granite transformed 4May 12, 2015 11:34 am girlfriday The material is a thin layer of caesarstone. Then do exactly what I said above. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Trimming a benchtop that has been granite transformed 5May 12, 2015 11:36 am Great - thanks for the advice! Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72337 0 9812 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18065 |
