Browse Forums Kitchen Corner 1 May 04, 2015 4:31 pm Will kitchen or stone places generally sell stone benchtops by quantity instead of requiring you to buy the whole slab and use only a tiny fraction of it? We only have two small sections of benchtop space:- 40cm x 60cm and 60cm x 60cm 3m x 1m seems a bit excessive. We are in the Hunter Valley if that helps. Amanda Re: Stone Benchtops 2May 04, 2015 7:01 pm cuebiyar Will kitchen or stone places generally sell stone benchtops by quantity instead of requiring you to buy the whole slab and use only a tiny fraction of it? We only have two small sections of benchtop space:- 40cm x 60cm and 60cm x 60cm 3m x 1m seems a bit excessive. We are in the Hunter Valley if that helps. Amanda It depends on the colour you choose! If you choose a colour that not many people use then they will charge you for a full slab. If you choose a well used colour then you will only be charged by the SQM There is a better way though, call the stone mason with your sizes and ask what off cuts he has. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7493 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5618 |
