Browse Forums Kitchen Corner 1 Apr 20, 2015 11:45 am Hello, I currently have an electric cooktop but am looking to replace with gas. We have a gas pipe (capped off) that runs under the house to the kitchen (heaps of clearance under the house with floorboards so I'm assuming the pipe work would not be difficult). I think that the pipe would need to be lengthened by approx. 1 metre to reach the cooktop area from where it currently ends. Can anyone give me an idea as to how much it would cost (hourly rate or estimate for the entire job) to install the cooktop. I'd like to spend about $1000 or less for the installation and price of cooktop - 60cm so the labour costs will impact in which brand we buy for the cooktop. This is a five year plan to tide us over until the kitchen is replaced entirely. Thanks! Re: Replacing electric cooktop with gas 2Apr 20, 2015 1:23 pm There are to many unknowns to be able to give you a price. You would be better of calling a local plumber and getting a quote! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Replacing electric cooktop with gas 5Apr 29, 2015 12:20 am aussieta also regulations for gas are different distance from hotplate to splashback and height from hotplate to rangehood dont remember the numbers but gas required about 50 - 100mm more Think you will find it is vendor specific. I have a Bosch pull out and minimum distance is 430mm for electric and 650mm for gas. But look at other brands and indeed other Bosch models and the distance varies but gas is further in all cases and under Australian standards is measured from the top of the burner not the actual hob. With gas and splashbacks, distance is and isn't an issue. With gas the splashback and any adjacent cupboards needs to be fire rated OR a minimum of 200mm away. Especially important if you have a glass or stainless steel splashbacks, because the splashback (for glass) needs to be specifically rated and the wall behind needs to meet specific requirements, 6mm fibre foard or 10mm gyproc.. Whereas with tiles, they mostly form the appropriate barrier due to their thickness and material. Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2778 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10865 |
