Browse Forums Kitchen Corner 1 Oct 22, 2006 6:25 pm We are currently getting our place ready to rent out.
I have just sourced a free, second hand stove top. It matches in terms of size and being gas... Will we be able to install it ourself or are we going to need a gas plumber??? Cheers Re: Installing new (2nd hand) stove top 3Oct 22, 2006 6:38 pm Get the gas plumber!! Especially if you are renting the home out. You don’t won’t anything bad to happen and come back onto you.
Make sure the job is done properly. There are some short cuts we should not take, I think this is one. Good luck. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Installing new (2nd hand) stove top 4Oct 23, 2006 6:54 am It will be an illegal as well as dangerous installation if you don't use a licensed fitter.
Also if you have a range hood don't forget that the clearance is different between gas and electricity. Earl Industrial Designer Re: Installing new (2nd hand) stove top 5Oct 23, 2006 10:25 am Thanks for that.
We had absolutely no idea whether it would be simple, legal etc etc etc... The plumber we call! Cheers Ask yourself if the insurance company will be aware of the Reno. 4 4875 Hi team, Im looking for a second hand sd4b monitor preferably white. 0 7313 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 2731 |
