Browse Forums Kitchen Corner 1 Mar 18, 2015 8:56 pm Hello, We are trying to avoid beading/corking throughout the house but we have run into a problem when it comes to the waterfall benchtop. As advised by the kitchen places and flooring installers we will be installing the kitchen first and then the floating bamboo floor. So how would we go about avoiding beading on the waterfall benchtop? One kitchen place is saying to put the benchtop on top of the floorboards while another is saying you can't do that and you need to floor to the benchtop, leave a gap and place beading on the gap. Anyone got any ideas of ways to avoid beading? Thanks. Corey Re: Alternative to beading around watefall benchtop 2Mar 18, 2015 9:33 pm We just done bamboo flooring and we have no beading, we got stainless steel kickboards, which were done after floorboards went in. So kitchen In first, then flooring, then kickboards, our granite last. I would avoid ugly beading or quad at all cost, can be done, just means kitchen guys coming back. Re: Alternative to beading around watefall benchtop 7Mar 19, 2015 10:09 pm We didnt want beading around our waterfall benchtop either. Our flooring guy cut some super nice cuts to our engineered blackbutt and we got an excellent finish. I know its not bamboo but we've had bamboo before i cant imagine why you couldnt achieve the same result. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alternative to beading around watefall benchtop 8Mar 20, 2015 7:47 am Yeah probably not Joker, I might have said floating floorboards and not specified that its bamboo. Wakudoki is yours just cut and butted against the benchtop or is it under? I thought you had to have a gap if it is cut up against it? Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51795 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7031 |
