Browse Forums Kitchen Corner 1 Mar 17, 2015 9:48 am Wanting opinions on Ceasarstone bench tops. I asked our builder for a price to upgrade from 20mm to 40mm with waterfall ends on the island bench (the std price with 20mm did not included waterfall ends) The upgrade is going to cost a extra $4300.00 After looking at the bechtops in their color studio, I noticed that the 40mm tops were in fact really only 20mm laminated. Where the sink was, was still only 20mm, but 40 mm at edges and 40mm on waterfall ends. Does this sound right? or should it be 40mm all the way? Is this a reasonable price? (I know thats a hard question without bench details) Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Re: 20mm or 40mm Stone? 2Mar 17, 2015 1:58 pm All CaesarStone 40mm tops are laminated, no such thing as solid 40mm!!! It really depends on the size of your kitchen but it sounds a little pricey to me! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 20mm or 40mm Stone? 3Mar 17, 2015 2:11 pm It's standard practice to make a 40mm edge profile with a 20mm lamination so there's nothing to be concerned about there. Ideally the lamination should be complete wherever it will be visible such as under a breakfast bar or in the internal face of a waterfall edge. It would be best to speak to your builder to confirm that the fabrication will meet your expectations. Re: 20mm or 40mm Stone? 4Mar 18, 2015 8:30 am What you have to take into account that just the waterfall ends will probably require an extra slab just for them and also the extra work involved for manufacture and installation of waterfall ends tends to boost the price a lot. Some kitchen companies are making the end panels on islands return the 900 deep and than returning back to bar panel to give a section of 50mm thick look at the back of the island. So the panel from the front is 18mm as all panels but when you look at the back of island the panel looks 50mm wide given the same look as waterfall end, sorry if my explanation is confusing. Not sure if cost much diff but i would imagine a wtaerfall end out of door material would be cheaper than stone but still looks very nice. Re: 20mm or 40mm Stone? 5Mar 18, 2015 12:20 pm Splashers What you have to take into account that just the waterfall ends will probably require an extra slab just for them and also the extra work involved for manufacture and installation of waterfall ends tends to boost the price a lot. Some kitchen companies are making the end panels on islands return the 900 deep and than returning back to bar panel to give a section of 50mm thick look at the back of the island. So the panel from the front is 18mm as all panels but when you look at the back of island the panel looks 50mm wide given the same look as waterfall end, sorry if my explanation is confusing. Not sure if cost much diff but i would imagine a wtaerfall end out of door material would be cheaper than stone but still looks very nice. Its still very pricey for the upgrade! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: 20mm or 40mm Stone? 6Mar 21, 2015 7:21 pm Solved by going half way..... 20mm is too thin, 40mm is only 20mm laminated soooo I went with 30mm Quantum Quartz. No joins and looks chunky enough Cheers, Paul (& Lisa) Parkhill 36 by ClarendonHomes in Coomera Retreat H1 Build Thread And Blog Building Blogs List - Go Ahead And Add Yours!! Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 |
