Browse Forums Kitchen Corner 1 Mar 09, 2015 2:13 pm Hello everybody, Its my first post, except for the intro thread. I am impressed with the wealth of information on this forum. I have had a new kitchen installed......well its partially installed because between the kitchen company and the installer its been a nightmare. When the old kitchen was pulled out, some of the gyprock behind the kitchen cabinets was damaged. This was plugged with sheets but was not stopped along the joins before the kitchen cabinets went back in. I am concerned as there is no longer an impermeable barrier between the inside and the outside. The house is brick veneer. Am I worried about nothing, or should this really be fixed. The gaps would be ~5mm at most. Regards Graham and Kathy Regards Graham and Kathy Owners of 2.5 acres of Paradise.......now working towards the house! Re: Gyprock behind kitchen cabinets. 2Mar 09, 2015 2:17 pm Grakat Hello everybody, Its my first post, except for the intro thread. I am impressed with the wealth of information on this forum. I have had a new kitchen installed......well its partially installed because between the kitchen company and the installer its been a nightmare. When the old kitchen was pulled out, some of the gyprock behind the kitchen cabinets was damaged. This was plugged with sheets but was not stopped along the joins before the kitchen cabinets went back in. I am concerned as there is no longer an impermeable barrier between the inside and the outside. The house is brick veneer. Am I worried about nothing, or should this really be fixed. The gaps would be ~5mm at most. Regards Graham and Kathy This actually happens more than people realise. Its not ideal but I wouldn't stress about it too much. Are you able to get to it yourself with some expanding foam or is it fully behind the cabinets? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Gyprock behind kitchen cabinets. 3Mar 09, 2015 2:26 pm Thank you for your prompt response. It is fully behind the cabinets. I think that, if I was doing the job myself, I would have stopped up behind the cabinets. In itself its probably not a major issue, but combined with all the other errors it becomes a bit too much to bear lol. Regards Graham and Kathy Regards Graham and Kathy Owners of 2.5 acres of Paradise.......now working towards the house! Re: Gyprock behind kitchen cabinets. 4Mar 09, 2015 3:17 pm Hi Grakat, I wouldn't be too concerned, providing everything is sealed when the kitchen is complete, then it should be ok. If you see gaps where pest can come through then there will be an issue. With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39714 6 11144 |
